pressure coorection
Old   August 3, 2009, 01:59
Default pressure coorection
rosa amerian
rr_amerian is on a distinguished road
Hello all,
I am a PhD student, writing a CFD code for a laminar flow in cylindrical axisymetric coordinate. I can not converge my code and I think the problem is in exerting boundary conditions of pressure correction equation.
I will be so thankful if anybody can send me the boundary conditions of Pressure correction equation in SIMPLE algorithm.
Thanks everybody.
Good Luck
rr_amerian is offline   Reply With Quote
Old   August 20, 2009, 04:54
Default RE. Pressure correction equation in SIMPLE algorithm
Mohammad Haddadi
m.iran is on a distinguished road
Send a message via Yahoo to m.iran
Normaly there are 2 kinds of conditions at boundary, either the pressure at boundary is given and normal velocity is unknown or vice versa.
1.Given pressure : if guessed pressure field is arranged such that at boundary P*= Pgiven, then value of the P' at the boundary will be zero.
2.Given normal velocity: for example if the velocity has be given just at western face, just the coefficient of aw at pressure correction Eq will be zero, and other coefficients don't change. and u* at west shouldn't be corrected. (because it is given as boundary condition and does not change) it is illustrated in Numerical heat transfer and fluid flow by patankar.
m.iran is offline   Reply With Quote
Old   August 20, 2009, 05:41
SKK
SKK is on a distinguished road
Have a look at the book 'An introduction to computational fluid dynamics, the finite volume method' by H. K. Versteeg & W. Malalasekera.
SKK is offline   Reply With Quote
finite volume, pressure correction, simple
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
