September 25, 2009, 18:32 |
analysis of naca2412 airfoil
gaurav
I am trying to analyse a 2-d model of a naca2412 Airfoil (cord length 1 meter) at an angle of attack of 16 degrees to calculate the coefficient of lift using "WIND-US" . But my solution never seems to converge. I have run about a 1,20,000 iterations yet it keeps oscillating consistently between 0.7 and 2.2. It keeps generating the same pattern. I have the following conditions pressure: 15.4 psi temperature: 540 R velocity: 0.2 Mach angle of attack: 16 degrees Laminar flow. I am using the roe scheme 3 order . Kindly suggest . Thanks. |
September 26, 2009, 21:33 |
naca2412 16 degrees
Dr Peter Murdoch
Sounds like its stalling. 16 degrees is close to the stall angle.
Check the pressure plot on the upper surface at the chord positions 0.2 0.4 0.6 0.8. If you really need to get this to solve try running it as a transient, start at 10 degree aoa and then slowly increase it. That should do the trick. |
September 26, 2009, 22:54 |
gaurav
Thanks a lot for your advice I shall definitely try it and get back to you.
Multi-element airfoil analysis | CFD Rookie | Main CFD Forum | 12 | November 17, 2016 06:07 |
airfoil analysis | Hammam | CFX | 10 | June 22, 2007 13:18 |
Airfoil Mesh for DES Analysis - y+ Value | asd | Main CFD Forum | 1 | May 3, 2007 10:13 |
y+ for Airfoil Analysis | asd | Main CFD Forum | 3 | April 18, 2007 10:54 |
quasi steady analysis of 2d airfoil (pitching) | Alex | FLUENT | 1 | February 10, 2006 02:54 |
