Cross-sectional Areas
Old   October 16, 2009, 13:00
Default Cross-sectional Areas
Ravi Dodd
ravids is on a distinguished road
Hi Guys
I have a rather strange problem for which I could not find a relevant sub-forum, hence posting it here.
After I create my meshed geometries in Gambit and run it Fluent and analyze the results in Tecplot, I wish to determine the cross-sectional areas of the branches of my geometry. I tried Geomagics, Gambit and Tecplot but there is no helpful feature to do this in any of these programs. Also, I need to find these areas at an exactly orthogonal plane to the branch (that is, no angle between the plane and the branch, just the exact area of cross-section). I tried another program called Solid-View Pro, but the cross-sections need to be perfect circles for this program to measure the areas. The areas in the geometries I use are NEVER circles (they are blood vessels, which are usually approximated to have circular lumen but that is not the case in the real world. They are irregular in shape).
Any help is greatly appreciated.
Thanks
Ravi.
ravids is offline   Reply With Quote
Old   October 16, 2009, 13:09
mrp
mrp is on a distinguished road
An easy way of finding the area is: after you've got the cross sectional disc, add a point at its centroid and then build triangules joining the edges on the disc to the centroid and calculate their areas. Sum all of them and you have the area of the cross section.
mrp is offline   Reply With Quote
flux through individual cells / face areas Mike FLUENT 2 February 16, 2009 10:43
Pressure drop between cross sections Mauro Main CFD Forum 0 September 13, 2007 02:09
Cross section and surface area factor Fabiana CFX 0 January 9, 2006 23:51
numerical stability due to cross derivatives wen long Main CFD Forum 2 September 12, 2005 02:10
k-omega, cross diffusion Emre Main CFD Forum 4 February 13, 2005 16:24
