pump-type flows
Old   December 19, 2003, 10:57
Default pump-type flows
grad
Can someone kindly shed light (references/suggestion) on bcs to use for a simple simulation of flows which physically take place in a loop with a pump (e.g pressure generating element using centrifugal or electric body force) and the generated mass flow is required as an OUTPUT quantity...
Are use of periodic bcs at inlet and outlet and how can I learn about themfundamentally and as regard to implementation (references)...
or is it appropriate to simulate the whole physical geometry of the flow-loop and solve as if it is a problem in an enclosure with no-slipat walls..
I have simulated the same with an imposed flow at inflow but my project objective is actually toget a generated flow..
Thanks in advance..
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 02:31
LiftDrag tool nuovodna OpenFOAM Running, Solving & CFD 45 September 2, 2009 17:56
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 05:49
