Two-phase flow in microchannels
Old   January 5, 2004, 05:24
Default Two-phase flow in microchannels
Shubidu
I have been doing turbulent flows and heat transfer in CFD for a few years now but I would appreciate your help with the following:
Modelling heat transfer of a fluid with the following properties:
a) two-phase flow (gas with several %'s oil)
b) fluid is evaporating (phase change)
c) flow regime is in the microscale
Which one of these points is the critical one? I don't think that a) is a problem but I don't know about the combination with b). In b) am trying to work out the latent heat that is 'absorbed' by the fluid (i.e. heat transfer coefficient). Is there a code available which is particularly well suited for the job? Or better still, can I use any of the standard codes (Fluent, CFX, StarCD, etc). Are there any issues that I should be aware of when modelling evaporation or latent heat? What about c)? Any ideas such as codes, problems, etc?
Any suggestions to one or all of the above topics would be greatly appreciated.
Two Phase Darcy flow with gravity -> problem Cyp OpenFOAM Programming & Development 0 November 17, 2010 07:58
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 10:20
Two phase flow in a distributor Mohsin FLUENT 5 May 24, 2010 02:57
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
More Probs - Gas-Solid 2 Phase flow Paresh Jain CFX 4 March 27, 2004 17:10
