Home > Forums > Software User Forums > COMSOL
Shear stress from velocity profile
Old   November 12, 2009, 06:46
Default Shear stress from velocity profile
Arun
baranii2000 is on a distinguished road
Dear all,
I was trying to calculate the shear stress due to fluid flow inbetween two parallel plates from the velocity profile taken from the middle of the flow channel (along vertical axis 'y') using comsol. The solution i got is two times the analytical solution i have calculated. The analytical equation i have used here is
Tou=viscosity*(Umax/h)
where tou is shear stress, umax is the max velocity
h is half of the distance between plates.
The calculation with velocity profile from comsol is done by
Tou= viscosity*(du/dy)
du/dy, i calculated with excel from the u,y values in the velocity profile.
the velocity profile is parabolic and looks laminar.
is that i am doing something wrong?
Thanks
Arun
baranii2000 is offline   Reply With Quote
Old   November 12, 2009, 07:04
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I don't remember the formulas but, if i understand well your problem, it is impossible that for the parabolic velocity profile the derivative at wall is equal to the one from the linear profile. Hence you should check your analytical formula for the stress (just take by yourself the derivative of the analytic velocity profile)
sbaffini is offline   Reply With Quote
Old   November 16, 2009, 20:16
Charles Rundle
Charles Rundle is on a distinguished road
I agree with the previous poster. I think your analytical solution is incorrect. Using a back of the envelope calculation I get a significantly different solution for the shear stress. I am assuming a laminar parabolic flow so depending on conditions my solution may not apply. Also since I mean the back of envelope quite literally I may have made an error.
Assuming your analytical solution is correct I would consider using a finer mesh. I would suggest that you plot your velocity profile against the analytical solution. The profile can look parabolic without truly being parabolic. The problem may simply be that grid resolution or insufficient convergence.
Lastly, your analytical solution may not valid for your Re.
I hope this is helpful. Have a good day.
CAR
Charles Rundle is offline   Reply With Quote
Old   November 18, 2009, 09:20
Arun
Thanks very much Paolo & Charles, i think i did a mistake in my analytical equation...it is supposed to be Tou=2*Umax/h*viscosity i dont know in many books they just refer to Umax/h...
Thanks
Arun
Old   November 11, 2015, 04:08
Default Shear stress in fluids
Dolores
malolagp is on a distinguished road
Hi
I'm trying to plot the shear stress in Comsol for the following problem from the velocity profile that I have previously approximated with Comsol.
Do somebody know how to do that?
Thanks in advance
Dolores
Consider two immiscible and viscous liquids, water and transformer oil, flowing at 300 k in the z-direction in a horizontal thin slit of length 0.5 m and width 0.1 m under the influence of a
pressure gradient. Both liquids can be considered as incompressible. At the inlet both liquids can be assumed to have the same pressure of 0.02 Pa. Determine the corresponding velocity profile for each fluid.
malolagp is offline   Reply With Quote
comsol, fluid flow, shear stress
Velocity Profile Jeff FLUENT 1 November 24, 2008 08:21
LES Near-Wall Velocity Profile Alex May FLUENT 2 June 12, 2008 12:36
Macro to set Wall Shear Stress Satish FLUENT 4 November 26, 2003 14:46
Re: About wall shear stress Mike FLUENT 9 November 17, 2003 14:41
How to get shear stress all over the flow domain lingo FLUENT 2 November 3, 2003 21:16
