3D-FLOTRAN ANALYSIS
Old   December 24, 2003, 02:18
Default 3D-FLOTRAN ANALYSIS
naidu
sir Iwould like to model a cooling tower model in ANSYS. plz help me in this regard. explain the procedure to carry the 3D ANSYS/FLOTRAN Analysis. thanking u.
Old   January 1, 2004, 17:00
Default Re: 3D-FLOTRAN ANALYSIS
peter
Don't use flotran. It's rubbish. You should use one of the professional tools like fluent,cfx,star-cd.
regards
peter
Old   January 2, 2004, 12:48
Roger Yang
This online tutorial may get you started.
http://www.oulu.fi/atkk/tkpalv/unix/...t/cfd_tut.html
Old   January 2, 2004, 13:52
naidu
Mr.Roger thanks for ur help, i had already practiced that problem but it could not help that much to perform 3D one. regards
Old   January 2, 2004, 14:12
Roger Yang
I am not sure I fully understand your problem.
1. If it is just 3D Vs. 2D, then the easiest way is to create the fluid region geometry from a CAD package then use IGES import to Flotran. You can generate geometry inside ANSYS too, but it's much harder. B.C.'s in 3D are very similar.
2. If it is the physics of the problem (is it a solid and CFD coupled problem?), there is another place you can look which is ANSYS verification problem collection, see link http://www.oulu.fi/atkk/tkpalv/unix/..._V_VMTOC1.html The link online is ANSYS 6.1 and there may be more coupled-filed examples in later version of ANSYS (Rev.7 & 8)
Good luck!
Old   January 4, 2004, 21:10
Derrek
Naidu:
The same exact concepts apply between a 2D and 3D analysis in FLOTRAN. In 2D you apply BCs to lines and in 3D it is to areas. Ensure you select the appropriate element type (FLUID142).
The most important thing is to understand the problem you are trying to simulate. Always try to simplify it to it's simplest form, but make sure you are accounting for everything appropriately. (ie. should you account for condensation/evaporation?) If so, FLOTRAN does not account for this.
Good luck!
Derrek
Old   January 5, 2004, 03:29
No_man
What makes you say this? Pleae elaborate.
Old   January 15, 2004, 12:53
Alexander
Where i can find example's for analys in Flotran of Heat Exchangers. Thank you in advance.
Old   January 15, 2004, 14:57
Roger Yang
There are over 230 verification problems in ANSYS User's documentation. You may find some thing close.
http://www.oulu.fi/atkk/tkpalv/unix/...p_V_VMTOC.html
Flow analysis in Ansys Flotran paritc ANSYS 0 March 25, 2010 23:51
3D analysis of Ahmed body Irshad22 FLUENT 0 December 17, 2009 04:33
What exactly is a sensitivity analysis? Josh CFX 3 August 19, 2009 09:18
Flotran analysis Vishwanath Main CFD Forum 1 September 25, 2001 23:23
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
