3D-Simulation of Steam generator (Sodium-water/steam heat exchanger)
Old   November 30, 2009, 23:35
Arrow 3D-Simulation of Steam generator (Sodium-water/steam heat exchanger)
Nandakumar
nandhubemech is on a distinguished road
This is Nandakumar,
Could any one suggest methodology and software for simulation of Once through counter flow steam generator heated by hot liquid sodium at low pressure on shell side, heating sub-cooled water into super heated high pressure steam on vertical tubes. Two phase flow is also encountered in this water side flow.
Earlier we have used 1D code for both sodium and water side, with heat transfer and pressure drop correlations for different boiling zones. Now we would like to simulate in 3D to find the temperature and flow mal-distribution radially, circumferential and axially. The SG is having 30m long 475 tubes each 12mm ID in 30mm triangular pitch.
Regards,
Nandakumar
nandhubemech is offline   Reply With Quote
Heat exchanger design sakthi Main CFD Forum 6 September 3, 2022 01:22
heat exchanger in typical air-conditioning system! Yang Bin Main CFD Forum 0 May 11, 2005 08:16
BIG TROUBLE with heat exchanger and porous media!! Andrea FLUENT 0 February 20, 2005 07:49
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
calculation of shell-and-tube heat exchanger alex Phoenics 4 August 28, 2001 03:06
