SMALLEST LENGTH SCALE
Old   January 22, 2004, 09:41
Default SMALLEST LENGTH SCALE
FRAN
HI GUYS, HOW CAN I FIND THE SIZE OF THE SMALLEST TUBULENCE IN MY BOX OF TURBULENCE. IT IS THE KOLMOGOROV SCALE I WANT BUT HOW DO I CALCULATE THIS. IS THERE AN EQUATION TO GIVE A GOOD ESTIMATE OF IT BEFORE DOING THE SIMULATION?
THANKYOU IN ADVANCE.
Old   January 22, 2004, 13:03
Default Re: SMALLEST LENGTH SCALE
Tim
The relationship I have for Kolmogorov scale is
Kolmogorov scale = ((nu**3)/epsilon)**0.25
where nu is kinematic viscosity and epsilon is turbulence energy dissipation rate..
Tim
Old   January 23, 2004, 04:45
Anyone.
Where can he get epsilon before starting a simulation?
Old   January 23, 2004, 05:16
Richard
The Tennekes & Lumley book is good for these estimates. Typically you would estimate epsilon from the fluctuating velocity (u or k=1.5u**2) and the length scale of the turbulence (L): epsilion ~ u**3/L.
If the turbulence is stirred, so you know the rate at which you are supplying energy to it, then you could take epsilon as equal to this supply rate - the energy just cascades down from the large scales.
Old   January 23, 2004, 06:40
Li Yang
The problem is that the fluctuating velocity or the kinetic energy varys from the position inside the boundary layer to the place outside of the boundary layer. The fluctuating velocity could be nearly zero in the viscous sublayer.Does that mean the length scale of the turbulence there is nearly zero ?
Could you enlighten me please ?
Old   January 23, 2004, 07:37
Tim
I found another, rather simpler, relationship for Kolmogorov scale...
Kolmogorov scale = d/(Red**0.75)
Where :
d is the charachteristic length,
Red is Reynolds number based upon characteristic length,
I am currently working on a channel flow case at Re = 32000, d = 0.01 therefore I get a Kolmogorov scale of 4.17E-6 M - does that sound resonable?
As for the comment about kolmogorov scale in the viscous sublayer - The viscous sublayer is a Laminar flow region - there are no turbulent eddies therefore there is not an applicable Kolmogorov scale.
Tim.
Old   January 23, 2004, 09:27
sylvain
Turbulence structures take their origine in the viscous sublayer region. So this region is very far from being laminar. The fact is that, in this region, most of the velocity oscillations are in directions // to the wall and turbulence structure looks like hairpin. Thus, from the mean average velocity point of view, this region looks laminar i.e turbulence doesn't act on it. But, for a DNS or LES this region is critical, turbulence structures appear there and there the velocity gradients are higher.
More over, in this region even if k and l tend to zero, the dissipation doesn't. It may mean that the turbulence spectrum glides to the very small scale.
Sylvain
Old   January 23, 2004, 11:20
Li Yang
That's is really an insightful discussion. Back to the question, how could we evaluate the length scale then ? eta=(nu**3/epsilon)**0.25. What value of epsilon we should use here ?
Nearly the wall, epsilon=u_tau**3/0.41y, where u_tau=sqrt(tau_wall/density)
For channel flow, tau_wall=Cf*density*U**2/2, where Cf=0.0706Re**(-0.25), Re=U*H/nu, H is the channel height.
When y moves towards zero (the wall), epsilon will be towards infinite, the length scale eta will be towards zero.
Please correct me if I am wrong ?
Old   January 26, 2004, 03:54
Richard
Remember that we're only talking about estimates of epsilon here. If we estimate that epsilon is u**3/L, then this doesn't confirm that epsilon is infinite at the wall. The most it tells us that epsilon has dimensions [L**2/T**3]. A good estimate in one part of the flowfield might be a very bad estimate in another part of the flowfield, where different physical effects dominate.
If you're particularly interested in epsilon at the wall, consider it's formal definition, 2*nu*<s_ij s_ij>. As it is a function of velocity gradients, which are finite at the wall, you'd expect espilon to be finite at the wall. From this finite value and the assumption that the velocity scale is u_tau, you could calculate the length-scale applicable at the wall, which is obviously nothing to do with the distance from the wall. But as you move away from the wall, it is reasonable to assume that the distance from the wall is the most important length-scale.
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Integral Length Scale vs Turbulent Length Scale Scott Nordsen FLUENT 2 January 20, 2014 01:17
LES inlet length scale f.neilson Main CFD Forum 0 January 31, 2005 13:26
Von Karman Integral Length Scale Txingurri Main CFD Forum 0 May 2, 2002 12:05
