Cells vs. Memory
Old   April 8, 1999, 03:04
Default Cells vs. Memory
Pavel
Hello everybody, I'd like to ask what is the function between number of cells and megabytes of memory in Fluent5. Otherwise how many megabytes do I need for every 10 000 of cells?
Thanks
Pavel
Old   April 8, 1999, 03:20
Default Re: Cells vs. Memory
Jonas Larsson
It depends on which solver you are using. The coupled solver tends to need more memory.
I'm just now running a ~300,000 cells case with the coupled solver (stationary) and it takes around 600 MB. YMMW.
Old   April 8, 1999, 10:32
Sung-Eun Kim
The memory requirement depends on the solver and physical models used. For 3D turbulen flow problems, the segregated solver in FLUENT 5 takes roughly 1MB of RAM per 1000 cells.
Old   April 20, 1999, 13:51
Alberto Tamm
First sorry for my bad english
It´s depend from the solver. Aprox. 1Mb RAM / 1000 cells (segregated)
Now i´m solving a 800.000 cells problem, MRF, segregated, K-E. with aprox. 500 Mb RAM
Alberto
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
