Research work references
Old   January 13, 2010, 01:40
Default Research work references
s Kumar
doctsh is on a distinguished road
Hi everybody
We have got plenty of CFD softwares to collect data for our research. Is it customary to give reference to the software that we are using? Because many publications dont inlcude details about software that they have used. What is the convention used?
Thanks in anticipation
doctsh is offline   Reply With Quote
Old   January 13, 2010, 09:00
Default referencing
CFDtoy
CFDtoy is on a distinguished road
Hi there,
Definitely one has to make sure he/she does include the software code used in the runs. This is because, although the fundamental eqns, assumptions may be universal, implementation of the terms are different in each code. This, tthey do so, in order to get robust stable solutions. Now, there are a number of ways to implement a term into the CFD code and hence, each has its own merits de-merits..so its better to say you used x software and obtained y result ..but with another z software you obtained "similar" but not the same result ...
It then becomes clear to readers what you have done and what is possible with the code you are mentioning.
in the journals, people do have to include the name of the code its more important..and if they have their own code utilized, they should have validated the code earlier and add the reference or provide validation of their code to simple problems within the article. This ensures that the code is acceptable to the standards.
Hope this helps.
/CFDtoy
Visit http://cfdtoy.blogspot.com
Originally Posted by doctsh View Post
Hi everybody
CFDtoy is offline   Reply With Quote
Why Fluent does not work on Linux? pzyss FLUENT 19 February 2, 2013 02:38
Fluent side work BJ FLUENT 0 June 23, 2006 16:48
Gambit.exe didn't work! Joshua FLUENT 2 March 25, 2005 19:17
NEED the bibliographical references for CFD modellin in libre surface Juan Carlos GARCIA SALAS Main CFD Forum 0 October 8, 1999 04:13
Research associate in US or UK? Liu Main CFD Forum 0 July 30, 1998 07:27
