April 30, 2010, 03:28 |
Problem with Axisymmetric solver
Ashish D. Shah
I am performing 2D axisymmetric simulation of flow in pipe. I prep the initial mesh in gambit and have aligned the axis to the X-axis, prepared a simple Quad Map mesh and then exported a 2D mesh. After importing it in Fluent, i checked the mesh and the minimum volume was +ve. I switched on axisymmetric mode under solver, then again checked mesh, it shows a -ve volume. What can be the reason? |
May 4, 2010, 07:56 |
Rami Ben-Zvi
For axisymmetry you should make sure the radius is non-negative, otherwise negative volumes may be created.
axisymmetric solver, negative volume |
Axisymmetric Vs 2D Flow problem | nikhil | FLUENT | 0 | March 29, 2010 23:52 |
boundary conditions for axisymmetric problem | eers | Main CFD Forum | 0 | June 19, 2009 14:52 |
problem with developing new LES solver | Edison_Ge | OpenFOAM | 2 | June 18, 2009 01:26 |
CFX 11 x64 solver? problem | Attesz | CFX | 6 | June 7, 2009 08:37 |
Can I use coupled solver for this problem | Frank | FLUENT | 0 | April 11, 2006 06:28 |
