Flat plate NS code
Old   May 3, 2010, 09:46
Default Flat plate NS code
varun
varunjain89 is on a distinguished road
Hi! all
i'm trying to write NS code over flat plate, using finite difference method, and Mac Cormack's technique. As described in CFD by j.d. anderson chaptr 10.
I have been trying it for past 1 month, with no luck yet. my predicted temp. keeps on decreasing, and my corrected temp keeps on increasing, and thus eventually @ one point, my predicted temp becomes negative.
has any1 of u ever tried this program, and help me out with it. or if you have faced such an error earlier.
any suggestions would be really helpful.
thanks a lot.
regards
varun
varunjain89 is offline   Reply With Quote
Old   May 3, 2010, 10:34
DoHander is on a distinguished road
I've implemented in the past the algorithm described in Anderson for the flat plate (Fortran 95) with no particular problem. If you follow carefully the description and do some hand calculation (just to check if your code does what is supposed to do) I'm sure you can achieve the same result.
Regrading the temperature I've obtained qualitatively the same graphics as the one presented in Anderson.
My suggestion is to carefully review the boundary conditions, usually the devil is in details.
Do
DoHander is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
CFD problem of 3d flat plate baggiojr FLUENT 0 April 7, 2010 14:26
Free convection flow over vertical flat plate Polly Main CFD Forum 1 February 11, 2003 13:25
Free convection flow over vertical flat plate Polly CFX 0 February 11, 2003 02:51
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
