airfoil trailing edge modelling in gambit
Old   June 2, 2010, 17:55
Default airfoil trailing edge modelling in gambit
morteza08's Avatar
Morteza
morteza08 is on a distinguished road
hi
i am modelling an airfoil in gambit to analyse shock occurance over airfoil.
is it important if the trailing edge is closed or not
see this http://www.herbcroft.com/untitled.jpg
please tell me what is the differences between the closed T.E and non closed T.E
i encounter a problem when i am trying to make a closed trailing edge airfoil in gambit when i am making the faces...could you plz tell me where is the problem?
morteza08 is offline   Reply With Quote
Old   June 2, 2010, 18:37
morteza08's Avatar
Morteza
Originally Posted by morteza08 View Post
hi
the link is damaged.... i attached the picture here
Old   June 4, 2010, 08:07
DoHander is on a distinguished road
In Gambit create two separate surfaces one for the part of your domain that contains the airfoil and one for the airfoil, then extract the airfoil face from the big face, this will work for your closed airfoil.
I think using an open TE (if the experimental data has mentioned the wing section was opened at TE - this is the case for a large part of NACA airfoils for e.g.) will give you more accurate results. However in CFD one usually close the TE to avoid meshing problems and to obtain a faster solution.
Check Cl, Cd and Cm for a NACA airfoil with closed and open TE for small angles of attack and then check these against experimental data from Abbott (you will see the difference).
Do
DoHander is offline   Reply With Quote
Old   June 4, 2010, 13:36
morteza08's Avatar
Morteza
you mean if i use open T.E , i will obtain more accurate results...
could u plz tell me why??
i want to know the philosophy behind this ?
does a open TE lead to more accurate result for flow after T.E like wakes.
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 08:11
Modelling 3D elbow in Gambit Karthik FLUENT 2 September 4, 2008 09:39
Modelling flow over airfoil at near stall angle Kelvin FLUENT 5 June 6, 2007 02:00
Aerofoils/blades with rounded trailing edge. Sergei Chernyshenko Main CFD Forum 6 July 26, 2000 05:10
trailing edge problem Kuo Wei-Jen Main CFD Forum 2 April 14, 1999 10:09
