June 12, 2004, 10:25 |
k-omiga model?
who can give the wall BC of k-omiga model? k=0, omiga=?
June 12, 2004, 12:52 |
Re: k-omiga model?
The best way to set omega is to use the surface roughness model developed by Wilcox (see for example his great book Turbukence Modeling for CFD). Even if you want a smooth wall it is still good to use the surface roughness model but set a hydralically smooth surface. This is more stable than most other omega bc's. If you haven't got Wilcox' book you should get it. In the mean time I think that you can find the surface roughness model briefly described in one of the papers I wrote as a PhD student (see my homepage: http://www.cfd-online.com/Users/jola/ ).
June 14, 2004, 09:13 |
Re: k-omiga model?
hi. you can use below bc for k-w mdel ( form menter paper) at inlet:w=5*Vin/L at free stream: w=1--10)V/L where V=10**(2--5) at wall: w=60*nu/(b*dy**2)- b=0.75
June 14, 2004, 10:52 |
Re: k-omiga model?
what is nu?
June 14, 2004, 20:01 |
Re: k-omiga model?
Read Appendix of the following paper. Medic and Durbin, 'Toward Improved Prediction of Heat Transfer on Turbine Blades' Transactions of ASME, Journal of Turbomachinery, Vol. 124, pp. 187-192, 2002.
Good Luck |
June 26, 2004, 07:00 |
Re: k-omiga model?
nu is kinematic vicousity
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
