k-omiga model?
Old   June 12, 2004, 10:25
Default k-omiga model?
lsm
who can give the wall BC of k-omiga model? k=0, omiga=?
Old   June 12, 2004, 12:52
Default Re: k-omiga model?
Jonas Larsson
The best way to set omega is to use the surface roughness model developed by Wilcox (see for example his great book Turbukence Modeling for CFD). Even if you want a smooth wall it is still good to use the surface roughness model but set a hydralically smooth surface. This is more stable than most other omega bc's. If you haven't got Wilcox' book you should get it. In the mean time I think that you can find the surface roughness model briefly described in one of the papers I wrote as a PhD student (see my homepage: http://www.cfd-online.com/Users/jola/ ).
Old   June 14, 2004, 09:13
javadi
hi. you can use below bc for k-w mdel ( form menter paper) at inlet:w=5*Vin/L at free stream: w=1--10)V/L where V=10**(2--5) at wall: w=60*nu/(b*dy**2)- b=0.75
Old   June 14, 2004, 10:52
lsm
what is nu?
Old   June 14, 2004, 20:01
Halim Choi
Read Appendix of the following paper. Medic and Durbin, 'Toward Improved Prediction of Heat Transfer on Turbine Blades' Transactions of ASME, Journal of Turbomachinery, Vol. 124, pp. 187-192, 2002.
Good Luck
Old   June 26, 2004, 07:00
javadi
nu is kinematic vicousity
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
