Periodic boundary conditions in tube banks
Old   June 18, 2004, 12:11
Default Periodic boundary conditions in tube banks
Zhihua
Hi, I am applying periodic boundary conditions in the simulation of flow flield and heat transfer in a circular tube bank in Fluent.Uniform temperature of 360 K is applied on cylinder walls and the upstream fluid temperature is 300 K. I found the following problems after running:
1. The average pressure at the inlet is about the same as the average pressure at the outlet. When I checked the pressure in the middle of the plane in x direction (the line that goes across the center circle), I found the average pressure is higher than that at the inlet. This is not reasonable because the pressure should decrease.
2. The average temperature at the outlet is lower than that at the inlet. This is wrong because the fluid should be heated up by the cylinder.
3. At the last 3 columns of meshes at the outlet , the temperature has a sudden decrease to about 68 K. I think there is something wrong with it.
Can anybody help me? Thanks very much!
periodic boundary conditions fro pressure Salem Main CFD Forum 21 April 10, 2013 00:44
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 19:04
Problem with using periodic boundary conditions Sun FLUENT 0 January 14, 2011 09:47
Pitchwise periodic boundary conditions aqib Main CFD Forum 0 November 7, 2010 14:00
periodic boundary conditions Satish Perivilli FLUENT 0 January 28, 2005 11:54
