KIVA simulating on parallel CPUs (64 bit machine) ??
Old   June 22, 2010, 05:44
Default KIVA simulating on parallel CPUs (64 bit machine) ??
Mori Nik
Mori-Nik is on a distinguished road
Hi everyone,
Does anyone know, what I need to do in order to run KIVA on few CPUs rather than one? I would be very grateful if you could help me to reduce the simulation time by running on few CPUs.
Cheers
Nik
Mori-Nik is offline   Reply With Quote
Old   June 24, 2010, 12:29
DaIN is on a distinguished road
Hi Nik,
First of all I need to know what version of KIVA you are dealing with and also whether that version is a parallel one or you would have to parallelize it by yourself.
Regards
daniel
DaIN is offline   Reply With Quote
Old   June 24, 2010, 12:42
Mori Nik
Hi Daniel,
Thanks for your reply,
I am using KIVA-3v, which I think needs to be modified first to run it in parallel.
Cheers
Nik
Old   July 15, 2010, 10:06
Hi Nik,
It's correct, KIVA 3V is a serial distribution of KIVA, so that if you want to run it in parallel you'll have to implement a parallelization in your code by yourself.
I can imagine that is not going to be easy at all
I'm using KIVA 4 which is a parallel distribution, then the parallelization is already implemented in it, so I have no clue about how to do it.
Good luck
Dani
Distributed Parallel on dual core remote machine Justin CFX 1 February 3, 2008 17:23
64 bit in parallel with 32 bit cluster Dr. Flow Squad FLUENT 2 December 5, 2007 06:34
Parallel Fluent: trouble going from 2 to 4 CPUs Mario FLUENT 6 August 24, 2006 00:17
CFX-5.7.1(Linux) Parallel - 4 CPU Machine James Date CFX 6 June 14, 2005 18:03
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
