v2-f turbulence model boundary conditions
Old   July 19, 2010, 11:58
Default v2-f turbulence model boundary conditions
tstorm is on a distinguished road
I've been working with the some v2-f turbulence models in FLUENT (they're user-defined, because my team won't spend money on the FLUENT v2-f model.)
I know the boundary conditions for k, epsilon, and v2, at inlets, outlets, and walls. But, I'm having trouble finding appropriate boundary conditions for f. I'm currently using a derivative of 0 at inlets and outlets and a value of 0 at walls, but I don't know if those are correct.
Has anyone worked with the v2-f models enough to know what the f boundary conditions should be?
Thanks in advance!
tstorm is offline   Reply With Quote
Old   July 19, 2010, 12:15
Correction: I'm using the f formulation by Lein and Kalitzin ("Computations of Transonic Flows with the v2-f turbulence Model"), and the f boundary condition at solid walls is f=0.
But I still don't know the appropriate inlet and outlet boundary conditions. Can anyone help?
Thanks again.
Spalart-Allmaras model, boundary and initial conditions vinz OpenFOAM Running, Solving & CFD 7 July 20, 2015 04:57
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
