k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet
Old   July 26, 2010, 09:45
Default k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet
Felipe B. Ch.
Felipeb is on a distinguished road
What are some unexpected producers of turbulent viscosity when using k-epsilon?
In our simulation, concentrically aligned free-jets are simulated for comparison with experimental data.
In this figure, turbulent viscosity measured on the domain's centerline is shown in red, the axial velocity measured on the domain's centerline is shown in green, and the experimental axial velocity data which we seek to match is shown in orange. These curves are overlaid on top of the domain which is shown in blue.
Why would k-epsilon produce the large amount of turbulent viscosity starting at about 40% of the length of the domain?
Grid dependency in the direction of flow has been eliminated.
Further simulation details:
  1. Fluent
  2. 2D Axisymmetric
  3. Incompressible
  4. Species Transport model Hydrogen-Air
  5. Concentric velocity-inlets: inner: Hydrogen, turbulence intensity 4%
  6. Concentric velocity-inlets: outer: Air, turbulence intensity of 3%
  7. Pressure inlet: Air, 1 atm
  8. Pressure outlet: 1 atm
Very grateful for any advice or suggestions on how to remove/remedy this non-physical turbulent viscosity production.
Felipeb is offline   Reply With Quote
Old   July 26, 2010, 17:02
Default k, epsilon, rho plot
Felipe B. Ch.
Below are plotted the constituent quantities comprising the turbulent viscosity in our simulation.
The turbulent viscosity is defined as follows:
From initial inspection of the plots, it looks like k is at fault.
Why would k suddenly jump at X/D = 8 ? Any suggestions?
Turbulent viscosity in a riser ap FLUENT 8 April 19, 2003 08:00
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
Asymmetric water free jet study Norberto Parreira Main CFD Forum 7 June 25, 2001 08:23
Turbulent viscosity Christian Holm Main CFD Forum 4 June 23, 2001 22:04
Radial jet with free surface using FIDAP Dr. Ahmed Hassaneen Main CFD Forum 0 October 28, 1999 13:20
