About Brackbill's Continuum Surface Force (CSF) model
Old   August 5, 2010, 16:52
Question About Brackbill's Continuum Surface Force (CSF) model
James Zhong
James is on a distinguished road
I am attempting to use Brackbill's Continuum Surface Force (CSF) model to simulate surface tension in a free-surface flow. For my simulation, the time step constraint imposed by the explicit treatment of surface tension is too tight. The allowable time step is up to the scale of 10^-9 second. Does anyone know any references which use an implicit treatment of surface tension under the framework of CSF? Thanks!
James
James is offline   Reply With Quote
Old   August 7, 2010, 14:27
Default Csf
Hans Bihs
valgrinda is on a distinguished road
Hei James,
I also use the CSF method for free surface flow, but I don't experience such drastic constraints for the timestep. Maybe your code has an error. Depending on your formulation of your Navier-Stokes Equations, you may need to dived the surface tension source term by the density (or multiply with the volume, if you use the finite volume method).
Cheers Hans
valgrinda is offline   Reply With Quote
Old   August 9, 2010, 12:04
James Zhong
valgrinda,
Thank you for your reply! I will double-check my code.
James
Old   August 10, 2010, 12:12
James Zhong
I noticed that in Brackbill's paper, the average density <Rho> = 0.5*(Rho1 + Rho2). In some other places, this density is taken as a volume averaged value. Which is way is good? Thanks!
James
Old   August 23, 2010, 06:09
Default CSF Implementation
Hans Bihs
Hei James,
check this paper for the implementation of the CSF model:
http://wissrech.ins.uni-bonn.de/rese...er/droplet.pdf
Regards
Hans
Continuum Surface Force Model Miguel Main CFD Forum 4 August 4, 2012 14:56
Surface roughness setting for a model in wind tunnel test section Sharon CFX 12 March 31, 2009 13:09
Surface tension - Continuum Surface Force model Robert Main CFD Forum 0 May 2, 2002 07:34
surface tension force Ray Main CFD Forum 0 October 17, 2001 15:42
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 11:57
