level set-starting trouble
Old   October 7, 2004, 12:44
Default level set-starting trouble
level set rookie
I'm going thru sethian's book on level sets.i dont understand how the level set function that is initialized as a signed distance function loses the property.and why does the speed function have to be defined again and again, as in the extension velocity method? it can just be computed directly from the values of the level set function phi itself, for example, in the case of curvature dependent flows. any answers? LS rookie
Old   October 7, 2004, 15:04
Default Re: level set-starting trouble
Junseok Kim
You can calculate the distance function loses the property under simple shear flow, say a droplet.
Check it out, because there is exact solution.
boundary conditions of level set equation Reza Main CFD Forum 7 July 8, 2019 04:18
level set reinitialization uter Main CFD Forum 2 August 3, 2015 09:31
using level set method rubby Main CFD Forum 2 March 7, 2009 02:02
boundary conditions of level set equation Amir Main CFD Forum 0 September 17, 2008 02:26
Level set equation in axisymmetric 2-D flow jinwon park Main CFD Forum 0 February 26, 2008 16:26
