Function of blade tip ring
Old   September 27, 2004, 10:39
Default Function of blade tip ring
Besso
Hi all
From the new automotive engine cooling fan, I saw that the fan blades are connected with a cylinder ring (like the duct rotating with the impeller). It looks good in strength point of view for a big size fan. Could any one tell what are the benefits and back draws aerodynamically?
Thanks
Old   October 23, 2004, 07:11
Default impeller+duct+marine water jet+modelling in gambit
hamid fouzan
i want some information for this subject
Old   November 9, 2004, 02:51
Default Re: impeller+duct+marine water jet+modelling in ga
ragoth singh
i am diong project in "design and modelling of centrifugal water pump volute casing" for M.E.(project work)
Old   November 9, 2004, 02:53
ragoth singh
i want elememtary idea about the design and modelling of volute casing for centrifugal pump for my M.E.(project work). please give some guidane and idea about this.
Old   November 13, 2004, 01:11
hamid fouzan
1- my english language is not good 2- i want subjects for marine water jet system 3-i want subjects for impeller,DUCT, marine water jet pump , flow in the pump, and fluid in to the duct , &FLUENT FOR THIS SUBJECT ** CAN YOU HELP ME? THANKYOU FROM YOUR ATTENTION.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
