January 26, 2011, 11:53 |
highly skewed elemnts in Gambit
anonymous
Rep Power: 15 |
I am simulating a flow and turbulence problem. The model is a very huge vertical pipe that has two structures which are obstructing flow in the pipe. As they are a bit complicated geometries so I meshed them first. Both have different volume, face and edge meshes. Now when I try to mesh the transition volume b/w those two (volume connecting those two strucutres) which is basically a pipe, I am getting the highly skewed elemnts. I am used tetmesh though it is a pipe because face and edge meshes on the faces of this volume are very different and can't be coopered. It says "Volume has 24 highly skewed elemnts Equisize skew > 0.97" when I use tetmesh. I tried splitting this transition into smaller volumes and meshing, which didn't work. I also tried reducing the mesh size, which didn't work either. What effect does these highly skewed elements have on the results? How can I get rid of them? Any ideas would be highly appreciated. Thanks. |
Highly Skewed Cells | chrisoturner | FLUENT | 7 | July 22, 2010 06:43 |
Highly skewed and inverted volumes in wing mesh | makaero | FLUENT | 0 | December 8, 2009 19:32 |
Can highly skewed elements create problem?? | Sanjay Jain | FLUENT | 1 | April 8, 2008 15:57 |
help: the volume mesh has highly skewed elements | xiaofish | FLUENT | 3 | September 18, 2007 09:51 |
what to do w/ highly skewed elements? (GAMBIT) | mike | FLUENT | 5 | June 2, 2007 22:10 |
