highly skewed elemnts in Gambit
Old   January 26, 2011, 11:53
Default highly skewed elemnts in Gambit
anonymous
rk2011 is on a distinguished road
I am simulating a flow and turbulence problem. The model is a very huge vertical pipe that has two structures which are obstructing flow in the pipe. As they are a bit complicated geometries so I meshed them first. Both have different volume, face and edge meshes.
Now when I try to mesh the transition volume b/w those two (volume connecting those two strucutres) which is basically a pipe, I am getting the highly skewed elemnts. I am used tetmesh though it is a pipe because face and edge meshes on the faces of this volume are very different and can't be coopered. It says "Volume has 24 highly skewed elemnts Equisize skew > 0.97" when I use tetmesh.
I tried splitting this transition into smaller volumes and meshing, which didn't work. I also tried reducing the mesh size, which didn't work either.
What effect does these highly skewed elements have on the results? How can I get rid of them?
Any ideas would be highly appreciated.
Thanks.
rk2011 is offline   Reply With Quote
Old   January 26, 2011, 18:24
gory is on a distinguished road
1. Viscous discretization may lose accuracy and lead to slow convergence (or diverge).
2. Accurate solution may look oscillatory when plotted.
gory
gory is offline   Reply With Quote
Highly Skewed Cells chrisoturner FLUENT 7 July 22, 2010 06:43
Highly skewed and inverted volumes in wing mesh makaero FLUENT 0 December 8, 2009 19:32
Can highly skewed elements create problem?? Sanjay Jain FLUENT 1 April 8, 2008 15:57
help: the volume mesh has highly skewed elements xiaofish FLUENT 3 September 18, 2007 09:51
what to do w/ highly skewed elements? (GAMBIT) mike FLUENT 5 June 2, 2007 22:10
