Post Processing of Turbine blade cases
Old   March 31, 2011, 18:59
Default Post Processing of Turbine blade cases
Martin
screech1987 is on a distinguished road
Ladies and Gents,
Currently I am looking to post process a batch of results utilising the same geometry and need to attain the a way of outputting the following, for which I have both Star CCM+ and Tecplot at my disposal:
1) boundary layer thickness (\delta), Momentum thickness (\theta) and shape factor (H).
Essentially this as far as i can see requires me to know the boundary layer thickness, and the rest can be interpolated from the corresponding location for other parameters. I have an approximation for \delta being roughly equal to 1.936ymax (the ymax being essentially a velocity gradiant based on wall distance).
Wall distance, velocity are all outputable from Star but I am at a loss how to script Tecplot (or Star) to search for the boundary layer edge.
2) Plots of coeffcients (CP,Cf etc) over a blade relative to the displacement along the blade surface. Star outputs coefficients easily these but relative to axial co-ordinates,rather than displacement over the skin/wall surface. So I guessed this was a job for Tecplot.
Hope the above makes some sense, and welcome any ideas. even if it just provides food for thought.
Also I apologise for not putting this in the CD-Adapco folder, as this involved Tecplot so was not sure.
Thanks for any help in advance,
Martin
screech1987 is offline   Reply With Quote
boundary layer thickness, star ccm+, tecplot, turbine blade
[ICEM] 3D turbine blade modeling ShaneStan ANSYS Meshing & Geometry 49 December 4, 2011 13:48
[Other] ANSYS CFX-Meshing problem of a wind turbine blade Zoe ANSYS Meshing & Geometry 1 July 14, 2010 02:02
[ICEM] Turbine blade with filleting and tip clearance Pursuor ANSYS Meshing & Geometry 4 July 7, 2010 13:56
Prisms for boundary layer mesh of turbine blade Andy QUB ANSYS Meshing & Geometry 1 April 16, 2010 12:05
Ansys Post Processing Brian_P Main CFD Forum 0 March 4, 2010 16:05
