January 27, 2005, 12:59 |
Human blood viscosity?
Does anyone know the value of human blood viscosity?
Thanks a lot. |
January 27, 2005, 15:51 |
Re: Human blood viscosity?
I`m afraid that there`s no unambigiuos answer. Dependent on whether the man is "well hydrated", dehydrated, thirsty, on his mood etc., the blood viscosity value varies from water-like to grease-like... and in grease-like state, it might easily be nonnewtonian...
January 27, 2005, 17:01 |
I mean for a healthy person under the normal body temperature.
January 28, 2005, 03:05 |
Well, I insist on my claim, it ain` that easy to state any simple and correct number. It may vary significantly even among healthy persons, at least women blood viscosity differs from men blood one... But at 37ฐC I would spot it to be somewhere between 3 and 5 maybe 6 mPa.s. However, if I remember the name well, Dr. Klabunde..... check the web for him, I think he made quite a lot in this field
January 28, 2005, 03:13 |
yes, klabunde is correct spell. he also a page of his own, blood related. also check this: http://www.clinchem.org/cgi/content/abstract/42/8/1189 I`ve been rght ;-)
January 28, 2005, 09:42 |
well its certainly thicker than water....
January 28, 2005, 14:50 |
Thanks kindly.
I also found this article yesterday. You are right that the blood is shear-thinning. Anyway, I just tried mu = 5.0 mPa.s and the results are in a good agreement with the available MRI data. Thanks again. |
Eulerian Modeling: Frictional Viscosity Help | meangreen | FLUENT | 1 | January 25, 2018 15:13 |
kinematic viscosity at diff temperatures,pressures | Mecobio | Main CFD Forum | 0 | November 7, 2005 12:55 |
blood flow simulation start-up hints please | olumide olododo | Main CFD Forum | 4 | May 31, 2004 11:33 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
viscosity of blood | Seung Yi | Main CFD Forum | 2 | July 26, 2000 09:52 |
