coal volatile composition
Like Tree2Likes
  • 1 Post By arnab
  • 1 Post By mj2malik
Old   April 30, 2011, 19:43
Default coal volatile composition
arnab is on a distinguished road
Hi all....
Could anyone please tell me how FLUENT calculates the volatile composition from proximate and ultimate analysis??.....
e.g. my coal analysis are:
Proximate(FLUENT input)[/B] (%)
FC-43.7
VM-45.6
Moisture-2.2
Ash-8.5
Ultimate(dry ash free basis)(FLUENT input)[/B] (%)
C-77.6
H-6
O-12.7
N-1.3
S-0.5
Ash-8.5
Proximate (Dry basis) (%)
FC-44.8
VM-46.7
Ash-8.5
Ultimate(Dry basis) [B] (%)
C-71
H-6
O-12.7
N-1.3
S-0.5
Ash-8.5
The volatile composition it shows in the coal calculator when I input these values is completely different what it comes out from hand calculation...
Hand calculation: (From dry basis of both)
wt%C in volatile = (71-44.8)/46.7 = 0.561 => moles = 0.561/12 = 0.04675
wt%H in volatile = (6.5)/46.7 = 0.128 => moles = 0.128/1 = 0.128
wt%O in volatile = (12.7)/46.7 = 0.272 => moles = 0.272/16 = 0.017
wt%N in volatile = (1.3)/46.7 = 0.028 => moles = 0.028/14 = 0.002
wt%S in volatile = (0.5)/46.7 = 0.011 => moles = 0.011/32 = 0.00034
So, Volatile = C0.04675 H0.128 O0.017 N 0.002 S0.00034
But FLUENT calculates (based on FLUENT input) :
C1.4 H3.78 O0.51 N0.0587 S0.0109
The FLUENT calculation is also not an exact multiple of hand calculation...could anyone please explain why is the discrepancy and how FLUENT calculates the volatile matter composition...
Thanks....
ramakant likes this.
arnab is offline   Reply With Quote
Old   May 13, 2013, 05:16
Talking
HKhalish is on a distinguished road
Hand Calculation
If you change the C ratio into 1, you will find the result quite similar
Hand Calculation
CH2.738 O0.364 N0.043 S0.007
CH2.7 O0.364 N0.042 S0.008
HKhalish is offline   Reply With Quote
Old   August 6, 2018, 13:03
Default adjusting the MW for the volatile
Jahangir
mj2malik is on a distinguished road
Include the molecular weight. It seems like for Fluent your MW for the volatile is around 30 kg/kmol.
Therefore, you should multiply the volatile MW value (kg/kgmol) to the mass fraction, before converting into mols.
So, for instance, if we take C for now
wt%C in volatile = (71-44.8)/46.7 = 0.561 * 30=16.83=> moles = 16.83/12 = 1.4025
This is applicable to the other elements in the volatile, which will give
alainislas likes this.
mj2malik is offline   Reply With Quote
coal gasification, dpm, fluent, volatile composition
Coal Combustion simulation Yogesh FLUENT 2 March 20, 2024 13:19
how to introduce volatile fraction in Multi-Phase coalgas FLUENT 0 February 11, 2010 00:21
Clean Coal Projects Clean Coal Projects Main CFD Forum 0 March 2, 2009 03:57
Coal combustion - volatile species Venky FLUENT 4 October 22, 2008 19:28
Coal gasification-problem with convergence Claudia FLUENT 7 November 8, 2005 02:08
