October 12, 2007, 19:02 |
Pros and Cons for CFX, CFdesign, COMSOL
Below are the pros and cons that I have been able to gather from reps and websites for these 3 packages. I would appreciate some insights based on your experience to help me select one of these (CFX, CFdesign, COMSOL) Multiphase flow - Pro = CFX, COMSOL; Con = CFdesign CFD-driven architechture (vs multi-physics approach) - Pro = CFX, CFdesign; Con = COMSOL Methodology used (which one is best?) - FV = CFX; FE = CFdesign, COMSOL Native Pro/E files - Pro = CFdesign; Con = CFX, COMSOL Dynamic manipulation of graphic results - Pro = CFX, COMSOL; Neutral = CFdesign; Con = COMSOL? Ease of use (for development Engineers w/ 0-3 years CFD experience - i.e. FloWorks) - Pro = CFdesign, CFX; Con = COMSOL Other modules (beyond CFD and Heat Transfer) - Pro = CFX, COMSOL (i.e. acoustics, non-linear FEA); Con = CFdesign Tech Support - Pro = CFX, CFdesign; Neutral = COMSOL; Con = none Future improvements - Pro = CFX; Con = CFdesign; TBD = COMSOL Cost - Pro = COMSOL,CFdesign; Con = CFX |
October 12, 2007, 19:18 |
Re: Pros and Cons for CFX, CFdesign, COMSOL
CFX also supports Native Pro/E Files in the exact same way as CFDesign.
September 1, 2010, 22:28 |
#3 | |
Derrek Cooper
Rep Power: 17 |
June 10, 2011, 02:20 |
Fluidyn CFD+Multi-physics tools
Rep Power: 14 |
fluidyn-MP is an interactive platform which uses the advantages of both Finite Volume Method (FVM) to solve fluid flow problems and Finite Element Method (FEM) to solve structural and acoustic related problems.
Eulerian-Lagrangian and Eulerian-Eulerian models are available for multiphase flows. Volume Of Fluid (VOF) method is used to solve free surface flow problems. Separate model is available to simulate combustion process. Various eddy viscosity turbulence models are available. Both surface and volume porosity based problems can be attended by fluidyn-MP. Local Thermal Equilibrium (LTE) and Local Thermal Non Equilibrium (LTNE) models are available to simulate heat transfer in porous medium. Anisotropy dispersion model is available for solute transport. Phenomena like boiling; condensation, melting, and solidification can also be solved. fluidyn-MP can deal with complex physical phenomena like electrolysis, and Magnetohydrodynamic flow with very high Hartmann number |
Pros and Cons | Jeremy Wu | Main CFD Forum | 2 | February 25, 2007 17:54 |
Gambit - Virtual Geometries (Pro's & Con's) | James Date | FLUENT | 3 | August 11, 2003 15:46 |
