April 3, 2005, 01:52 |
Drag Coeffecient Calculation
I solve structured grid volume arround sphere using navier stocks equations , it exact the same flow paths like those produced from fluent, when i calculate the drag coeffecient, it always gives different values for different sphere diminsion, i use pressure*area integration arround all ponits of sphere border to get the drag force, but i always get wrong value of Cd (1.3-->4.9), any one can tell me the reason and how to detect the problem in my code?
April 4, 2005, 13:26 |
Re: Drag Coeffecient Calculation
1. Include viscous drag in your calculation
2. Cd will change with Re which in changing when you change the dimensions. -- Jarmo |
April 4, 2005, 14:33 |
Can you please give me a valid fromula to calulate the prssure and viscuse terms in the drag force. i want to be sure of my equations?
April 5, 2005, 12:10 |
Pressure drag - pressure * area Viscous - viscosity * du/dn * area
Or something along those lines. Any fluids book should have this. -- Jarmo |
April 7, 2005, 20:15 |
hi ! Even i am writing a code for Cd but it is around a cylinder. Please help me in grid discritization as i am mesing up th grid thts why i got errors. Please give me links or method of grid u used so tht I can have an idea for a cylinder
Thanks ANy help will be appreciated |
April 8, 2005, 14:07 |
actually i use a structured gride "cubes" arround the sphere, it is more simple for calculation, put untill now i fail to get an accurate value for Cd
Calculation of Drag Coefficient manually | PRASHANT GHADGE | FLUENT | 4 | December 13, 2012 15:31 |
Pressure drag calculation | lc05 | Main CFD Forum | 2 | November 1, 2010 07:50 |
drag calculation help | abcdef123 | Main CFD Forum | 1 | May 9, 2010 23:00 |
Drag Calculation... Code_Saturne? Or any other examples? | ArtyB | Main CFD Forum | 1 | January 10, 2010 18:18 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
