Drag Coeffecient Calculation
Old   April 3, 2005, 01:52
Default Drag Coeffecient Calculation
Mohamed Sobh
I solve structured grid volume arround sphere using navier stocks equations , it exact the same flow paths like those produced from fluent, when i calculate the drag coeffecient, it always gives different values for different sphere diminsion, i use pressure*area integration arround all ponits of sphere border to get the drag force, but i always get wrong value of Cd (1.3-->4.9), any one can tell me the reason and how to detect the problem in my code?
Old   April 4, 2005, 13:26
Default Re: Drag Coeffecient Calculation
Jarmo Monttinen
1. Include viscous drag in your calculation
2. Cd will change with Re which in changing when you change the dimensions.
-- Jarmo
Old   April 4, 2005, 14:33
Mohamed Sobh
Can you please give me a valid fromula to calulate the prssure and viscuse terms in the drag force. i want to be sure of my equations?
Old   April 5, 2005, 12:10
Jarmo Monttinen
Pressure drag - pressure * area Viscous - viscosity * du/dn * area
Or something along those lines. Any fluids book should have this.
-- Jarmo
Old   April 7, 2005, 20:15
Shrinivas
hi ! Even i am writing a code for Cd but it is around a cylinder. Please help me in grid discritization as i am mesing up th grid thts why i got errors. Please give me links or method of grid u used so tht I can have an idea for a cylinder
Thanks ANy help will be appreciated
Old   April 8, 2005, 14:07
Mohamed Sobh
actually i use a structured gride "cubes" arround the sphere, it is more simple for calculation, put untill now i fail to get an accurate value for Cd
Calculation of Drag Coefficient manually PRASHANT GHADGE FLUENT 4 December 13, 2012 15:31
Pressure drag calculation lc05 Main CFD Forum 2 November 1, 2010 07:50
drag calculation help abcdef123 Main CFD Forum 1 May 9, 2010 23:00
Drag Calculation... Code_Saturne? Or any other examples? ArtyB Main CFD Forum 1 January 10, 2010 18:18
Warning 097- AB Siemens 6 November 15, 2004 04:41
