How do you think this will perform?
Old   July 18, 2011, 08:52
Default How do you think this will perform?
Tom
xTamx420 is on a distinguished road
I have this sort of aerofoil shaped profile that I am currently testing with ANSYS Fluent to get a plot of lift versus angle attack. I got the results for the lift coefficient at 4 degrees this morning and it seemed a little low at 0.1. The profile is made of a NACA 0030 leading edge with a 440 mm flat section in the middle and a 0035 trailing edge.
A lift coefficient of 0.1 seems too low for a NACA foil but then I started thinking it might be reasonable for a lift coefficient of a flat plate. Do you think this shape would perform like a flat plate and not a NACA foil or am I doing something wrong in Fluent?
Tom
xTamx420 is offline   Reply With Quote
Using 'define init' macro to perform a calculation at the start of a simulation jonnythewlis FLUENT 0 May 21, 2010 07:23
Difficult to perform YPLUS grid adaption.... Dowsenar FLUENT 0 February 11, 2007 00:46
How to perform a particle track in CFX(10) post? Jordan CFX 2 September 28, 2006 12:03
Why k-epislon model perform a bad result at corner Lwrence CFX 13 April 8, 2006 07:46
Can i perform translating motion in Tascflow?? Zix Toh CFX 0 March 10, 2004 05:21
