flow around a cylinder
Old   April 9, 2006, 03:13
Default flow around a cylinder
pXYZ
I am searching data of a flow around a cylinder (for comparison). Do you know any good reference?
Thanks.
Old   April 9, 2006, 05:05
Default Re: flow around a cylinder
ramp
Hi !! I hope the following reference will provide you all the data...
[1] Ahmad, R.A., 1996, Steady-state numerical solution of the Navier-Stokes and energy equations around a horizontal cylinder at moderate Reynolds numbers from 100 to 500, Heat Transfer Engg., 17: 31-81.
[2] Chakraborty, J., Verma, N. and Chhabra, R. P., 2004, Wall effects in the flow past a circular cylinder in a plane channel: a numerical study, Chem. Engng. Processing, 43: 1529-1537.
[3] Coutanceau, M. and Bouard, R., 1977, Experimental determination of the main features of the viscous flow in the wake of a circular cylinder in uniform translation. Part 1: Steady flow, J. Fluid Mech., 79: 231-256.
[4] Coutanceau, M. and Defaye, J.-R., 1991 Circular cylinder wake configurations: a flow visualization survey, Appl. Mech. Rev., 44: 255-305.
[5] D'Alessio, S. J. D. and Dennis, S. C. R., 1994, A vorticity model for viscous flow past a cylinder, Comp. Fluids, 23: 279-293.
[6] Dennis, S. C. R. and Chang, G.-Z., 1970, Numerical solutions for steady flow past a circular cylinder at Reynolds number up to 100, J. Fluid Mech., 42: 471-489.
[7] Dennis, S. C. R. and Hudson, J. D., 1995, An $h^4$ accurate vorticity-velocity formulation for calculating flow past circular cylinder, Int. J. Numer. Meth. Fluids, 21: 489-497.
[8]Dennis, S. C. R., Hudson, J. D. and Smith, N., 1968, Steady laminar forced convection from a circular cylinder at low Reynolds numbers, Phys. Fluids, 11: 933-940.
[9]Fornberg, B., 1980, A numerical study of steady viscous flow past a circular cylinder, J. Fluid Mech., 98: 819-855.
[10] Fornberg, B., 1985, Steady viscous flow past a circular cylinder up to Reynolds number 600, J. Comp. Phys., 61: 297-320.
[11] Ding, H., Shu, C., Yeo, K. S. and Xu, D., 2004, Simulations of incompressible viscous flows past a circular cylinder by hybrid FD scheme and meshless least square-based finite difference scheme, Comput. Methods Appl. Mech. Engng., 193: 727-744.
[12] Hamielec, A. E. and Raal, J. D., 1969, Numerical studies of viscous flow around circular cylinders, Phys. Fluids, 12: 11-17.
[13] Kawaguti, M. and Jain, P., 1966, Numerical study of a viscous flow past a circular cylinder, J. Phys. Soc. Jpn., 21: 2055-2062.
[14] Sucker, D. and Brauer, H., 1975, Fluiddynamik bie quer angestromten Zylindern, Warme- and Stoffubertagaung, 8: 149-158.
[15] Takami, H. and Keller, H. B., 1969, Steady two-dimensional viscous flow of an incompressible fluid past a circular cylinder, High-Speed Computing in Fluid Dynamics The Phys. Fluids Supplement II, 12: 51-56.
best regards..... Ramp
Old   April 10, 2006, 03:11
Anton Lyaskin
I can also add M.M. Zdravkovich, Flow Around Circular Cylinders, Oxford University Press, 2003
Old   April 10, 2006, 03:27
ramp
[1] M.M. Zdravkovich, Flow Around Circular Cylinders, Vol. 1 Fundamentals, Oxford University Press, 1997
[2] M.M. Zdravkovich, Flow Around Circular Cylinders, Vol. 2 Applications, Oxford University Press, 2003
Old   April 12, 2006, 15:11
pXYZ
Thanks a lot. I have already found some of the posted titles.
Unfortunately the book "Flow Around Circular Cylinders" is very expensive!!! I am actually looking for papers or summaries to investigate the influence of different turbulence models. Unfortunately, I didn't find any inforamtion about it in the publications (Journal of Fluid Mechanics). Even velocities, geometrical data, temperatures are rare.
So, I would appreciate, if you have further ideas for me.
Old   April 12, 2006, 16:40
ramp
Hi !! May be the following (or cross references) can give you something:
[1] Norberg, C. (2003). Fluctuating lift on a circular cylinder: Review and new measurements, Journal of Fluids and Structures 17 (1), pp. 57-96 29
[2] Norberg, C. (2001). Flow around a circular cylinder: Aspects of fluctuating lift, Journal of Fluids and Structures 15 (3-4), pp. 459-469
[3]Norberg, C. (1994). Experimental investigation of the flow around a circular cylinder: influence of aspect ratio, Journal of Fluid Mechanics 258, pp. 287-316 96
[4] Norberg, C., Sunden, B. J. (1987). Turbulence and Reynolds number effects on the flow and fluid forces on a single cylinder in cross flow, FLUIDS & STRUCT. 1 (3 , Jul. 1987), pp. 337-357 9
[5] Norberg, C. (1985). INTERACTION BETWEEN FREESTREAM TURBULENCE AND VORTEX SHEDDING FOR A SINGLE TUBE IN CROSS-FLOW, Journal of Wind Engineering and Industrial Aerodynamics 23 (1-3), pp. 501-514
Best regards.... Ramp
Old   April 13, 2006, 02:03
pXYZ
it sounds quite promising - but I am not sure if I will be able to access the Journals. If it isn't too much work for you it would be fantastic if you could send them to me by mail (mailto: pxyz@hotmail.com).
Best regards...pxyz
Old   April 13, 2006, 08:46
pXYZ
Please forward any literature to pxyz@hotmail.de, (if possible!)
Thanks a lot.
Old   April 13, 2006, 15:09
ramp
Hi !!
Find it in your mailbox...
Best regards.... ramp
Old   April 13, 2006, 18:00
pxyz
Hi ramp,
thanks a lot!!!! I just found your mail, that's why I didn't read the papers --> but I will.
Best regards, pxyz
Old   April 24, 2006, 16:04
  #11
Mayo Adetoro
Can you forward this papers to me as well:
my mail is: madetoro@yahoo.co.uk
Regards. Mayo
Old   April 24, 2006, 16:36
  #12
ramp
Hi Mayo....
Forwarded these papers, find in your mailbox
Best regards... Ramp
Old   October 22, 2010, 05:19
Jugal
jugal44j is on a distinguished road
Hey can any one from you 3 persons (Ramp, Mayo & Pxyz) forward this papers to me?
My email address is jugal44j@gmail.com
I am also working on same topic"Flow around cylinder". I need some data to compare.
Thanks in Advance....
jugal44j is offline   Reply With Quote
Old   July 25, 2011, 05:23
Default 3D flow around a rectangular cylinder
  #14
olawore Ayodeji
olaworesly is on a distinguished road
can you guys send me some copies. im working on 3D flow around a rectangular cylinder. pls send it to olaworesly@yahoo.com
olaworesly is offline   Reply With Quote
Old   July 25, 2011, 10:05
A.D.E is on a distinguished road
I would be grateful for some copies as well since I am looking into similar phenomena!!!
Thank you in advance,
A.D.E
adecfd@gmail.com
A.D.E is offline   Reply With Quote
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
1 Was FSI for a flow over a cylinder vmlxb6 CFX 17 May 16, 2011 02:29
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 13:55
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 26, 2007 23:26
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
