Staggered Grid representation in code
Old   March 14, 2011, 08:55
Default Staggered Grid representation in code
batabek is on a distinguished road
Hi all,
I want to use a Staggered grid for simulating a fluid flow. If I use a regular array structure(for instance float u[] in C/C++, etc.) I'm unable to represent the floating point coordinates such as (i+1)/2, (j+1)/2..., which are required for the velocities found on the cell faces. What is the correct way to handling these? Thanks in advance.
batabek is offline   Reply With Quote
Old   July 17, 2011, 07:08
Default RE
Nathan
nathand is on a distinguished road
i think you should try more than one set of grid points, or you can use finer grids but allocate different physical values at different grid points. hope this will help.
nathand is offline   Reply With Quote
Old   July 17, 2011, 08:06
HouKen
houkensjtu is on a distinguished road
just multiply them by 2...
houkensjtu is offline   Reply With Quote
Old   July 17, 2011, 10:30
Mazhar Iqbal
mazhar is on a distinguished road
I believe you should use same grid numbering for the pressure and velocity. the only diffrence is that velocity calculations will start from grid point 2.
mazhar is offline   Reply With Quote
Old   July 23, 2011, 19:08
Vincent
VincentD is on a distinguished road
It does not really matter too much how you denote your locations, however you yourself should understand it.
I would make all the matrices with the same kind of numbering. So U(i,j) would be the x-dir velocity to the right of my pressure cell P (i,j) and V(i,j) my y-dir velocity above the Pcell.
If you include BCs into the problem your total matrices would have a size:
P(nx+2,ny+2) with nx*ny interior points
V(nx+2,ny+1) with nx-1*ny ''
U(nx+1,ny+2) with nx*ny-1 ''
VincentD is offline   Reply With Quote
How can i apply staggered grid method in circular domain? heisenbergg Main CFD Forum 1 April 1, 2010 17:05
Parallel FVM on staggered grid ertan Main CFD Forum 2 November 5, 2009 11:25
To avoid Grid generation for FORTRAN CFD CODE Stephen Main CFD Forum 4 January 30, 2006 03:04
code for turbulent non-orthogonal curvilinear grid Abhi Main CFD Forum 0 October 18, 2002 08:58
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 00:18
