Compiling kiva3 with fortran 77 on unix
Old   May 6, 2005, 08:15
Default Compiling kiva3 with fortran 77 on unix
T.Sencic
When I try to compile kiva3 on an Silicon Graphics Octane with
fort77 kiva3.f
I obtain the following message:
"kiva3.f", line 29194: warning(2038): floating constant is out of range
if(dabs(work(i4)).lt.1.0e-90) work(i4)=0.0
"kiva3.f", line 29194: warning(2061): floating-point value does not fit in
required floating-point type
### Assertion failure at line 629 of ../../common/com/stab.c: ### Compiler Error during Scope Setup phase: ### overflowed maximum number of types fort77 INTERNAL ERROR: /usr/lib32/cmplrs/mfef77 returned non-zero status 1
What should I do to make it run? Should I try a later fortran version, should I use a fort77 option, change something in the code? Any sdvice is welcome.
Old   May 6, 2005, 12:48
Default Re: Compiling kiva3 with fortran 77 on unix
steve
I'm guessing that 1.0e-90 is too large of an exponent. why don't you try 1.0e-30.
Old   May 18, 2005, 05:15
harish
Try using 1.0de-90. Also might try compiling with
f77 -ff90 option
-H
Old   November 5, 2010, 07:43
Default How to decide NBO in iprep file
shahid
shahidimran is on a distinguished road
can any one guide me how to decide NBO value in iprep file of kiva3... if decided how to select i,j ,,x,y for all these [points
thanks
shahid
shahidimran is offline   Reply With Quote
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Error occurs when compiling Fortran in CFX-4.4 zhaoyangly259 CFX 1 June 9, 2010 06:28
Error while compiling Fortran routine Manoj Kumar CFX 3 January 25, 2006 04:08
about USER FORTRAN compiling issue CXL CFX 1 October 9, 2003 21:00
Error when compiling user fortran Mads Bang CFX 1 October 8, 2002 11:47
