PIPE JUNCTION
Old   May 19, 2005, 08:02
Default PIPE JUNCTION
kamesh
hello I have a pipe and it is seperated into two at a joint(something like y-pipe).I am using SIMPLE scheme and trying to calculate the Turbulent kinetic energy.I am using standard k-epsilon model.My boundary conditions are mass inlet at inlet ans prescreibed pressures at outlets.My wall is adibiatic. I have observed the pressure residual initially increased to 1.5e+02 (250 iterations) and then stated decreasing very slowly to 1.2e+01 (900 iterattions aprox)and is still continuing.I am intersed in steady state solution. I want to increase the convergence criteria.I have been playing with underrelaxation factors. Any suggestions for improving convergence rate and also some comments on initial increase of pressure residual inspite of other residuals decrease. thanks..kamesh
Old   June 5, 2005, 16:59
Default Re: PIPE JUNCTION
Mohan
In my opinion you could look at the grid you have especially at the junctions. Good luck
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
[blockMesh] Cylindrical pipe junction fugu OpenFOAM Meshing & Mesh Conversion 8 September 14, 2010 05:09
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
