May 25, 2005, 18:06 |
Looking for test case
Good day all,
May someone give me a test case for isothermal gas computation in 1D? Web source would be appreciated. I just wrote a solver using MUSCL-Hancock scheme with Roe's FDS and want to prove it. Many thanks in advance! -W.M. |
May 25, 2005, 23:37 |
Re: Looking for test case
Do a search for Sod or shock tube problem. It's a fairly common test case and there should be plenty of references.
May 26, 2005, 03:45 |
http://www.grc.nasa.gov/WWW/microbus/
this i guess has a 1d sod's case, you can compare ur solution with it. |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
Doubt in unsteady case | vijay | FLUENT | 1 | April 24, 2006 11:11 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 10:25 |
