September 12, 2011, 10:57 |
HELP! Flow over both sides of a plate.
Hi. I am modeling a air flow through a plate with small holes and constant heat flux for the convective heat transfer coefficient.
For the plate, I am actually drawing the thickness of the plate since I will need the CHTC on both sides. I can set 'coupled' for the second line, which represents the bottom side of the plate. My problem is, fluent will automatically create a 'shadow' plate for the upper side of the plate. And if I leave the 'shadow' plate as default, there will be no thermal profile along the plate on the upper side, which is totally wrong. If I set certain heat flux to the 'shadow' plate, the thermal profile will appear. But should I suppose to divide the heat flux to two portions, one for the regular upper face and one for its shadow? The CHTC obtained will not be the one I desire. Can anyone explain why? and how to fix this problem? Thank you very much. |
chtc, shadow walll |
compressible laminar flow over flat plate | varunjain89 | Main CFD Forum | 19 | April 18, 2019 06:07 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
incompressible, 2-D laminar flow over flat plate... | varunjain89 | Main CFD Forum | 3 | March 6, 2012 11:13 |
supersonic flow over flat plate | varunjain89 | Main CFD Forum | 1 | March 23, 2010 08:26 |
heat transfer on dimpled plate | mech | FLUENT | 4 | February 6, 2007 15:15 |
