radiation between solids in CFX
Old   September 15, 2011, 17:28
Default radiation between solids in CFX
groonm is on a distinguished road
Hi all,
When modelling the heat removal by fluid I got problems in setting the proper radiation conditions/method. The model comprises two solid bodies separated by the vacuum. One body with volume heat generation is a radiation emitter with a certain emissivity of radiating surfaces. Another body is a radiation collector with the same (or different) emissivity of the surfaces and has a cooling channel with water circulating. The radiation heat exchange occurs between solids only. The question is how to simulate this radiation? I tried Monte Carlo method, surface-to-surface option with opaque boundaries and emissivity set to some value (0.8) As a result, the first body (emitter) reaches some equilibrium temperature, while the second does not receive any heat remaining at the initial temperature.
Could anybody who faced similar problems clear up? I would appreciate!
groonm is offline   Reply With Quote
radiation in CFX george CFX 28 January 10, 2019 17:13
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
Solid to Solid Radiation hossein Main CFD Forum 0 April 17, 2008 09:32
Thermal radiation with solids rotating luis CFX 0 March 16, 2008 21:04
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
