Apply Rotation Speed of Rotating Region
Old   September 19, 2011, 09:48
Default Apply Rotation Speed of Rotating Region
John Moore
Joke is on a distinguished road
I'm designing propeller and I want to know how much thrust its generating compare to my hand calculation (Blade element theory).
I modeled solid propeller and covered it with rotating region. If my propeller should turn in clockwise direction in the real wolrd such 1400rpm, so when I apply rotational speed of rotating region, that speed direction should be couter-clockwise direction which be -1400rpm ---> Am I right?.
The result that I got when I applied condition as above is the reverse thrust (such as -500N) I wonder why this reverse thurst happen ???
Thank in advance
Joke
Joke is offline   Reply With Quote
MRFSimpleFoam - Selection of rotating region Ivanet OpenFOAM Running, Solving & CFD 8 May 22, 2015 09:17
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
Rotating region of a centr. pump - Counter R wall Emre CFX 0 September 20, 2007 09:58
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
