density gradient driven mass flows in gases
Old   September 19, 2011, 11:38
Default density gradient driven mass flows in gases
Mirko Vukovic
mirko is on a distinguished road
I am struggling to understand how the following problem can be stated within the two-species species Navier-Stokes equations with diffusion.
The following is an incompressible, low-pressure gas flow in the hydrodynamic regime.
Consider a long thin tube, left half filled with a light gas (hydrogen, helium), the right half with a heavy gas (Argon, Xenon). The two halves are separated by a barrier. Gases are at same temperature and pressure.
At time t=0, we remove the barrier, and the gases start diffusing. Since the light gas is diffusing in to the heavy gas, and the other way around, there is a mass flow from the right to the left.
Questions:
I can derive diffusion driven mass flow the diffusion equations. How do I couple that with the Navier Stokes equation?
Momentum transfer is handled by the Navier-Stokes equations. But the NS equations only have external forces and the pressure gradient as the driving term. Is the diffusion the external forcing term?
What am I missing?
Thank you,
Mirko
mirko is offline   Reply With Quote
Density of air for calculating the mass flow rate from Darcy's law Hermano Main CFD Forum 0 August 22, 2011 11:17
Specifying vertical density gradient in FLUENT ajagan FLUENT 0 August 18, 2011 22:16
lid driven turbulent flows student Main CFD Forum 0 July 20, 2007 12:43
Pressure correction in Buoyancy driven flows Aditya Main CFD Forum 0 March 8, 2007 06:36
Multiphase, Bubbly flows, Virtual Mass KP Main CFD Forum 2 July 18, 2005 10:46
