Need help about negative k for k-omega model? |
June 2, 2005, 06:11 |
Hi, everyone,
i'm implementing standard k-omega model proposed by Wilcox based on unstructured mesh by FEM method. BC at wall for Omega is 60.0*dynamic visc/(beta*dy^2), which was proposed by mentor and for k is equal to 0. I use k-l result as initial soultion for k-omega. To my suprise, after first newton-raphson interation, all k is negative inside the mesh domain. i checked many times that the equtions are correct for sure, but i couldn't undersatnd why it's like that. Pls. give me your suggestion and comments. Thanks for your help. |
June 24, 2005, 22:19 |
Re: Need help about negative k for k-omega model?
It could be the way you are writing your source terms. Have a look at the following link to see how to make sure that source term gives positive values.
http://personalpages.umist.ac.uk/sta...r/turbcfd2.pdf |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 10:36 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 02:39 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 20:51 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 19:13 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 05:24 |
