intermittency transport equation
Old   June 10, 2005, 05:58
Default intermittency transport equation
dirk
has anyone experience with intermittency transport models for (successfully) simulating the transition over a separation bubble, especially in Fluent? Any comments will be appreciated.
Thanks, Dirk
Old   June 24, 2005, 22:10
Default Re: intermittency transport equation
Sheila
I am modeling intermittency using STAR CD. I will be using my model to calculate flow over turbine blades which will be highly prone to seperation.
Since you hav'nt mentioned excatly what you need to know, I will give you a rough idea of what to do based on what I am doing.
Solve the intermittency equation as a scalar. In STAR CD we have the option to solve for a scalar and supply the source and diffusion terms via user defined subroutines. I am pretty sure similar options are available in Fluent. You have to be very careful with boundary integral variables, such as boundary lare thickness, momentum thickness etc as accuracy of intermittency calculation depend greatly on these. In STAR CD, we have no option but to write our own program for these variables.
Once the intermittency is solved properly, it is then neede to be incorporated into the actual flow calculation. According to the model I am using, intermittency comes into play only in momentum equation. It enters the momentum equation by changing the turbulent viscosity term,
mu_t_new = intermittency x mu_t_old
With regard to flow seperation, I am using intermittency model by Yildirim Bora Suzen. You can find relevant papers from this link http://www.engr.uky.edu/%7Esuzen/publications.html
Hope this helps. Good luck. Sheila
Solving Transport equation for additional variable using CFX creddy_trddc CFX 11 April 2, 2015 21:07
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
UDF Transport equation for transition momentum thickness Reynolds number Wantami FLUENT 0 April 9, 2011 02:50
Is it possible to use divergence in the source term of an scalar transport equation? jannnesss CFX 0 January 8, 2010 19:53
Turbulent Heat Transfer Transport Equation Flo.duck Main CFD Forum 0 May 6, 2009 03:37
