Modelling of infinite cylinder
Old   November 6, 2011, 05:09
Default Modelling of infinite cylinder
bibelka is on a distinguished road
Hello!
My question may sound stupid, however it is very important to me.
How to model boundaries in z-direction in infinite cylinder, assuming the flow is turbulent?
Sorry, if something is unclear from my description.
bibelka is offline   Reply With Quote
Old   November 6, 2011, 17:07
cfdnewbie
cfdnewbie is on a distinguished road
there are no stupid questions
Just use periodic bcs in the z-direction, that should do the trick. what kind of turbulence modelling are you doing? LES?
cfdnewbie is offline   Reply With Quote
Old   November 7, 2011, 02:47
Thanks!
RANS, actually, however hope that periodic will still work =)
Old   November 7, 2011, 15:20
cfdnewbie
Yes, in a way, RANS is the only method in which periodic BCs work without any limitations!
Good luck!
Old   November 8, 2011, 01:30
Thank you! =)) And what are the disadvanteges or limitations of using RANS? LES is a good alternative or not?
Old   November 9, 2011, 11:32
cfdnewbie
that's a very broad question. Just the basics: RANS assumes that your mean flow is steady, and models the lumped effect (dissipation) of turbulence. Also, RANS works not to well for separated flows and complex geometries.
LES resolves the larger vortices of the flow, and models only parts of it, so it is inherently unsteady, but many times more expensive than RANS....
that's just a quick answer, there are many more aspects to this. What in particular interests you?
Old   November 9, 2011, 11:33
Zachariah Swetky
swetkyz is on a distinguished road
Meaningful usage of LES is very difficult. Meshes must be much finer, and care must be taken in setting up the simulation.
There is a great deal of good information in the following AIAA paper:
"Large-Eddy Simulation: Current Capabilities, Recommended Practices, and Future Research." Georgiadis, N. J. et. al.
You may want to do the RANS simulation, and if you find that you want to resolve the turbulent structures more explicitly, try LES as a deeper exploration into your problem.
Good luck!
-Zachariah
swetkyz is offline   Reply With Quote
boundaries, infinite cylinder
Modelling of fluid flowing from a cylinder Phil FLUENT 1 May 7, 2008 01:09
PLEASE HELP HELP modelling free vibration cylinder Ken FLUENT 0 June 23, 2007 11:35
2D cylinder modelling pieizquierdo (miguel) FLUENT 0 January 10, 2005 16:59
infinite cylinder Glenn FLUENT 1 September 19, 2002 08:58
infinite cylinder Glenn Main CFD Forum 0 September 16, 2002 09:49
