Typical runtime for simulation with mesh movement? |
August 17, 2005, 09:46 |
hi,
I've read quite a few papers which simulate wings of insect (3d) or airfoil (2d) flapping. The Re should be 10^3 - 10^4. Does anyone knows what's the typical run time for 1 or 2 cycles, assuming using the university's super computing facilities? Does it need to take months? thanks alot! |
August 22, 2005, 07:13 |
Re: Typical runtime for simulation with mesh movem
It depends not only on the facilties but also on the procedure that you would be using to compute the unsteady aerodynamics. I am not sure about the 3D case but i am able to get solutions for typical 2D problems in a time of 1-2 hrs. Suriya |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
