Setting Solid Emissivity
Old   February 15, 2012, 15:51
Default Setting Solid Emissivity
Yuri Singha
yus310 is on a distinguished road
I'm currently using the S2S model to model a gray enclosure which has 5 different surfaces. The only problem is that ANSYS does not allow me to set the "internal emissivity" for the solid regions, only the fluid regions. I was wondering if anyone can help with this regarding, whether or not, I can set the internal emissivity for the solid regions.
Thank you,
Yus310
yus310 is offline   Reply With Quote
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
solid surface's emissivity jarno brunetti FLUENT 2 December 23, 2005 04:54
solid surface's emissivity jarno brunetti FLUENT 0 December 21, 2005 04:51
Warning 097- AB Siemens 6 November 15, 2004 04:41
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
