Oscillations during processing
Prev Previous Post   Next Post Next
Old   September 6, 2005, 06:51
Default Oscillations during processing
DAK565656
Such a fundamental problem, but I didn't see disquisition. Solving absolutely steady problem of external flow I achieve sometimes residual oscillations for pressure and components of velocity. Maybe the reason is wrong timestep, but how can this timestep influence on steady problem? Changing properties of mesh may result in convergent or divergent solution. Changing the thickness of BL for only 1 mm. from convergent solution thickness can lead to divergent solution. This results are very sad. This means that I have to use different mesh properties for each geometry (for each angle of attack in my case) that don't lead to divergence...
Numerical oscillations in LES due to mesh refinement Soder OpenFOAM 0 June 14, 2011 10:10
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
bubbly flow and parallel processing mvee FLUENT 0 September 12, 2007 05:08
spurious oscillations and upwind-scheme Chandra Main CFD Forum 0 March 27, 2007 03:26
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
