Flow Result Accuracy
Old   February 22, 2012, 10:53
Default Flow Result Accuracy
Jimmy
wildabyss is on a distinguished road
I was performing turbulent flow modeling with Fluent on an untapered rectangular wing with an aspect ratio of 6.6, at an Re of approximately 1e6. The airfoil is NACA0015. I used the S-A turbulence model with low-Re correction.
I performed validation using a VLM solver (AVL) for lift, moment and induced drag, and the fully turbulent flat plate solution for skin friction drag. As can be seen from the plots, the CL and CD agree pretty well. How come the CM is more than 3 times off?
wildabyss is offline   Reply With Quote
Old   February 22, 2012, 16:25
Martin Hegedus
Martin Hegedus is on a distinguished road
Cm is always tricky, and the hardest, to compare.
One of the better metrics is to calculate the error in the center of pressure or aerodynamic center, in your case, dxac = (cm1-cm2)/cl = (3.25e-2-1.0e-2)/1.0 = 2.25e-2. So your aerodynamic center is off by 2.25 percent of the chord. (Assuming your reference length is the chord length) This is to be expected.
Martin Hegedus is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Cavity air flow with radiation – result variable Yingchun CFX 1 November 25, 2005 11:13
