March 9, 2012, 05:32 |
Problem with the k-omega model
Joachim
Rep Power: 15 |
Hello everyone!
I have a problem with a simulation, and I thought that maybe you could help me... Actually, I am new at CFD, so this will maybe sounds simple to you. Anyway it isn't for me. I am supposed to model a 2D airfoil (M, Re, AoA, etc given) with different turbulence models and then compare the results. First, I have established a grid convergence using Spalart Allmaras, and obtained very nice results in agreement with the experimental data. Then, I decided to try my fine mesh (150k cells) with the k-w model. The problem: the turbulent viscosity is too high, or the temperature...well, it doesn't work. Am I supposed to create a new mesh for the k-omega model? I have uploaded some pictures of my mesh, do you see something wrong? There is y+=1 everywhere. Thank you very much for your help! Joachim |
March 9, 2012, 14:56 |
Holger Dietrich
Rep Power: 15 |
Hello Joachim,
the expansion factor of the mesh shouldn't exceed 1.2, especially in the region near the blade - is that given? Furthermore why dont you use the SST-model instead of k-omega? The SST-model uses a switching function to give good results in the near-wall-regions (like k-omega does) and even far away from the walls (like k-epsilon does). |
airfoil mesh k omega |
Problem with turbulence model | akonduri | OpenFOAM | 2 | September 17, 2010 00:49 |
Turbulence model for mixing problem??? | nileshjrane | Main CFD Forum | 7 | September 14, 2010 04:57 |
Problem in Herschel-Bulkely model | emad | FLUENT | 0 | May 20, 2009 14:20 |
Non premixed model - combustion validation problem | David | FLUENT | 2 | October 24, 2003 10:06 |
Two phase Eulerian Model Problem | senthil | FLUENT | 5 | May 21, 2003 02:55 |
