September 13, 2005, 04:32 |
visualization freeware
hi guys, can you recommend a free visualization software for WinNT? available on the web, simple thought easy-to-operate, making nice pictures, able to read structured data... I've went through may be 100 pages, many of them are out-of-date, on many of them you cann't download anything, many of the codes are primarily for unix, etc etc. have hardly found two somehow suitable codes: SeLaVi - a bit clumsy manipulation and occassionally returns error message for which I cann't find the reason and the authors' emails don't work.
I don't run any special or large sized cases, 1D/2D euler eq., up to approx. 10,000 cells thanks |
September 13, 2005, 04:46 |
Re: visualization freeware
Visit is very good and free http://www.llnl.gov/visit/executables.html
Also try MayaVi http://mayavi.sourceforge.net |
September 13, 2005, 05:19 |
Check out the links here:
http://www.cfd-online.com/Links/soft.html#vis ParaView and MayaVi are nice. OpenDX is powerful but a bit of tough to get started with. |
September 13, 2005, 07:31 |
Paraview would be my choice!
http://www.paraview.org It is a visualization tool, very easy to learn, based on VTK with support for several file formats, including Ensight (MayaVi is also based in VTK). I´ve provided some Fortran routines in order to export data in Ensight's format in the following link: http://www.nacad.ufrj.br/~rnelias/paraview Regards Renato N. Elias |
September 13, 2005, 10:58 |
can you give a quick example how the data format look like for structured mesh? given: x,y,q with imax,jmax. thanks.
Visualization of higher order solution | shyamdsundar | Main CFD Forum | 1 | July 23, 2010 03:55 |
freeware | mike | Main CFD Forum | 3 | April 1, 2001 20:50 |
help: flow visualization library | soofuu | Main CFD Forum | 3 | September 28, 2000 10:54 |
CFX4-Interface for OpenDX Visualization Software? | Doris Rieger | Main CFD Forum | 0 | December 1, 1999 06:41 |
Flow Visualization of impinging swirling flow on the wall. | sangaria | Main CFD Forum | 2 | March 26, 1999 13:31 |
